Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to make a intercooler cool better
Old 05-29-2012, 08:10 PM   #27
oknvragain
Fan#: 48054
What I Drive: 06,RED,ZX3
Points 876, Level 15
Points: 876, Level: 15 Points: 876, Level: 15 Points: 876, Level: 15
Level Up 76% Completed
FF Reputation: 1 oknvragain Good Standing Member
Originally Posted by sporadic View Post
You have probably figured this out by now, but here is what I did to help intake temps. Results on post #10 and more pictures around post #20.
Opened up the bumper for the FMIC
Thats what I was looking for. I ended up making a heat shield for my alternator to fix the problem with the rear bearings failing. The real test will be the next couple months as the Texas heat is starting to climb. The back of the alternator went from 300 degrees F plus to 124 degrees after a 20 min hwy drive.
i'd like to cut the bottom of the bumper out a little to open up the bottom 3 1/2 fins on the intercooler. Though I don't want it to look horrible. What did you use to finish off the edges. Your turned out great.
2.0 Duratec
Custom GT28R Turbo build
3 Inch Exhaust...... NOW 2.5 Inch
42lb bosch injectors
Tune by Tom
oknvragain is offline
