Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Turbo Installation Advice?
Old 05-24-2012, 02:27 PM   #41
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 880, Level 15
Points: 880, Level: 15 Points: 880, Level: 15 Points: 880, Level: 15
Level Up 80% Completed
FF Reputation: 3 amoosenamedhank Good Standing Member
Originally Posted by sporadic View Post
This is not accurately stated. The CFM most certainly is dictated by the turbo, by both the turbine side and the compressor side.
A small turbine housing will restrict flow, and a small compressor will restrict flow.
There is too much over-simplification in your explanation and the original poster needs to do far more reading on their own rather than expect to get all the answers here by non-professionals, including myself.
Go to the Garrett website and read everything before accepting anything you read here as fact.
EDIT: I'll add that I recommend not buying a single piece of your turbo kit until you can read, understand, and plot points on a compressor map relative to your power goals.
If you don't want to do any of this, then just buy a pre-made kit from a company that has done all the research already.
Regardless of what you have for a turbo, your intake track and combustion chamber are not variables. Changing your turbo sizing will not change this. A larger turbo will reduce back pressure, this will result in better evacuation of the combustion chamber...therefor improving the VE of the engine.
What's that?? You'd like an eco-tune...
amoosenamedhank is offline
