Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 5-Door tail lamp scratching body
Old 05-24-2012, 08:40 AM   #36
silenthill
Fan#: 85671
What I Drive: 2012 Focus SEL hatch
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
FF Reputation: 2 silenthill Good Standing Member
After three visits and finally getting the tail lamp adjusted so it's not tight against the body, I finally pulled the housing off yesterday to take a look at the paint. As was mentioned by others in this thread, it's really easy and is actually the way that you replace burnt out bulbs, and the directions are in the manual. This is what I found:
IMG_4420 by silenthill2011, on Flickr
As you can see, the one chip is pretty large, and there's scratching towards the bottom. I also didn't realize that the housing also chipped some paint off at the very top of the fixture, near where the tail lamp meets the hatch window--the dealer touched this up pretty well, so you may need to look closely:
IMG_4432 by silenthill2011, on Flickr
Anyway, I'm glad the mystery of how to get the tail lamp housing to not rub against the body seems to be solved, but I'm a bit concerned about potential corrosion issues down the road.
silenthill is offline
