Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dropped valve seat - what's it look like?
Old 05-23-2012, 01:18 AM   #18
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
What I Drive: 5.9L Grand Cherokee ZJ
Points 24,482, Level 95
Points: 24,482, Level: 95 Points: 24,482, Level: 95 Points: 24,482, Level: 95
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 76 mikebontoft Excellent Standing Member
Buy-Sell-Trade Rating: (3)
Lower mileage than that of other that have failed. remove your spark plugs, see if any are smashed. also try to shine a light into the cylinders.
with the plugs out, you should be able to crank the engine aroubd with the starter... should go pretty slow though.
if you don't see any visible signs as mentioned above, it may be time to pull some bearings on the bottom end. At the same time though, check for metal chunks of the piston in the oil pan etc.
I wouldnt doubt that if the seat dropped just right it could seize the engine though.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parted) | '75 BMW 2002 "Carby" (racecar) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (daily).
Moderating
and
mikebontoft is offline
