Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rattling heat shield fix.
Old 05-22-2012, 05:34 PM   #1
JBotone
JBotone's Avatar
Fan#: 78479
What I Drive: 2003 Pitch Black SVT 5 door
Points 1,176, Level 18
Points: 1,176, Level: 18 Points: 1,176, Level: 18 Points: 1,176, Level: 18
Level Up 76% Completed
FF Reputation: 1 JBotone Good Standing Member
Talking Rattling heat shield fix.
Hey everyone,
I just fixed my rattling heat shield. I hate rattles and it had rusted around the bolts like they all do, and was hanging loose. I didn't feel like just removing it, as everything is so close in the engine bay I didn't want the extra heat ruining anything.
You will need.
10 mm socket for top bolts
6 or 7 mm socket for bottom bolts (I could not get mine out..too rusted)
12 washers 1/16th thick, 1 in OD, 1/4 ID
6 metric bolts 10mm head 5mm thread size (Just match up old with new)
Here is what I did.
1) Took out 4 top bolts (Luckily they were easy after some PB Blaster) Bottom bolts would not come out for me.
[IMG][/IMG]
2) Move heat shield enough to slide one washer underneath each hole, and line up with mounting hole on header.
[IMG][/IMG]
3) Use one washer with each new bolt, and tighten down. IF you can't get the lower bolts out, this will hold the heat shield tightly enough to keep it from rattling.
[IMG][/IMG]
I hope this helps.
2003 Pitch Black SVTF, K&N Drop in, CFM dog bone. 155,000 miles. **SOLD**
2001 Sentra SE 2.0 w/JWT Pop Charger. RETIRED with 511,000miles.
2008 Setra SE-R Spec-V 187whp. 167 lb. ft.
JBotone is offline
