Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - anyone using premium gas ?
Old 05-22-2012, 03:47 PM   #122
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,806, Level 25
Points: 1,806, Level: 25 Points: 1,806, Level: 25 Points: 1,806, Level: 25
Level Up 6% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by dyn085 View Post
You didn't read this all the way, did you?
I've read that article in the past, and I just read it again. There is nothing in that article that supports gtp2focus's claim that fuel detergent additives "keep carbon deposits away from your valves" in DI engines.
Granted, it does state that some engine manufacturers have found ways to reduce or eliminate valve deposits, but none of the methods mentioned relates to the cleaning of valves from fuel additives.
The methods mentioned are:
improved components such as high-pressure solenoid injectors
injection-timing calibration
optimization strategy with valve events
redesign of EGR systems to reduce particulates
redesign of PCV systems to reduce particulates
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
