Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to remove steering wheel
Old 05-22-2012, 11:07 AM   #13
kaptinkurk
Fan#: 98769
What I Drive: 2012 Sterling Grey Sedan
FF Reputation: 1 kaptinkurk Good Standing Member
Originally Posted by amoosenamedhank View Post
So to answer your question... the typically procedure is to remove the airbag fuse and pull the negative battery terminal. Once you do that give it at least 20 minutes and some recommend to press the brake pedal to completely drain the system. The pyrotechnic squib is of course still in the airbag, but with out an electric charge to ignite it... you should not be in risk of blowing the thing off in your face.
I agree with everything you said in your post, however even with all of these precautions you should still be very careful. You may assume that the airbag has no electrical charge do to the battery and fuse being taken out, however most modern air bags have capacitors that hold energy for the air bag to use in result of this exact case happening in a crash or other accident.
kaptinkurk is offline
