Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus K&N Intake kit Released.
Old 05-21-2012, 09:13 PM   #161
wantz12
wantz12's Avatar
Fan#: 89237
What I Drive: 2012 White FF Hatch
Points 2,610, Level 31
Points: 2,610, Level: 31 Points: 2,610, Level: 31 Points: 2,610, Level: 31
Level Up 7% Completed
FF Reputation: 2 wantz12 Good Standing Member
Originally Posted by Joeywhat View Post
If you remove the battery cover you can clearly see that ground point connects directly to the battery.
But this doesn't interrupt the circuit, which is why they say disconnect the negative. So if this is the case, disconnecting the ground simply means the system is ungrounded.
EDIT: I'm an idiot. As an electrical engineer...I'm quite ashamed of myself right now...
2012 Ford Focus SEL Hatchback
K&N Typhoon Intake | 3d Carbon Wing
HN #167
wantz12 is offline
