Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus K&N Intake kit Released.
Old 05-18-2012, 02:12 PM   #130
troy-knfilters
troy-knfilters's Avatar
Fan#: 85424
What I Drive: 2000 Ford Taurus SE (FFV) Vulcan
Points 2,234, Level 28
Points: 2,234, Level: 28 Points: 2,234, Level: 28 Points: 2,234, Level: 28
Level Up 56% Completed
FF Reputation: 1 troy-knfilters Good Standing Member
To answer your question, the same as if you disconnect the negative. However the positive being re-connected is more dangerous than the negative mostly because when your tigtening down the positive your tool can touch a metal surface causing a bad arc, if you look at your factory manual under roadside emergencies you will notice that they say to connect the positive first and the ground last.
http://www.motorcraftservice.com/pub.../12focog4e.pdf
Page 315
Troy.
Resident K&N Guy - Got a Question about a K&N Product? Let me know - I can help!
troy-knfilters is offline
