Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Exhaust tip Focus 2012 - would this fit?
Old 05-18-2012, 01:03 PM   #28
ricomtl
ricomtl's Avatar
Fan#: 97818
What I Drive: 2012 Focus Titanium Hatch Tx. Black
Points 875, Level 15
Points: 875, Level: 15 Points: 875, Level: 15 Points: 875, Level: 15
Level Up 75% Completed
FF Reputation: 1 ricomtl Good Standing Member
Originally Posted by bassmobile View Post
Yep. There are three threaded studs that you use to secure it to the exhaust pipe. You'll need a hex driver or allen key for that. Get those nice and tight.
Then there are three nuts that go over each of the threaded studs. Those secure the threaded studs and keep them from loosening. Tighten those down and you should be good to go. As I mentioned, mine is not going anywhere. After reading some of the other posts, I rechecked mine and as I said it is not going anywhere. Nice and tight.
thanks again!
ricomtl is offline
