Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Mk3 Recalls and TSBs
Old 05-17-2012, 10:51 AM   #12
Fan#: 99099
What I Drive: 2012 Ford Focus
FF Reputation: 1 Imaruningbulseye Good Standing Member
I think it for that one
FORD: 2006-2007 Focus
This article supersedes TSB 06-25-2 to update the model years and Service Procedure.
Some 2006-2007 Focus vehicles may exhibit a squeaking noise from the rear of the vehicle over bumps. This noise may be caused by contact between the rear parking brake cable sleeve and the wire form bracket located under the vehicle near the rear suspension tie bar being transferred into the vehicle body.
Follow the Service Procedure steps to correct the condition.
Remove the parking brake cable bolt. (Figure 1)
Figure 1 - Article 08-4-15
Insert the plastic insert into the square hole used for locating the parking brake cable guide. (Figure 1)
Remove any existing grease from the cable guide and cable (in this area only) by wiping clean with a suitable service towel.
Install the cable guide onto vehicle by inserting the locating tab of the guide into the center of the plastic insert and reinstalling the parking brake cable bolt. Torque to 17 lb-ft (23 N-m).
Imaruningbulseye is offline
