Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2013 Order Guide Released
Old 05-14-2012, 01:03 PM   #124
Pretherius
Pretherius's Avatar
Fan#: 97062
What I Drive: 2012 SE Sedan 5-Spd Sterling Gray
Points 1,256, Level 19
Points: 1,256, Level: 19 Points: 1,256, Level: 19 Points: 1,256, Level: 19
Level Up 56% Completed
FF Reputation: 1 Pretherius Good Standing Member
Originally Posted by csvt2060 View Post
Several of you guys have the physics all wrong. Whether the mass is on the front or rear, the brakes overall are still slowing down the same amount of mass. The difference between the front and rear brakes is the available traction to the tires, which does increase to the front as the load shifts. That's why the brakes are set with a front bias.
I was hesitant to add to the OT topic, but too much bad information. Back to the topic.
This is worse than what others were saying before you.
The mass does not shift forward or backward (for the purposes of this discussion); the weight does. Weight is a measure of force, and it DOES change as the car's velocity changes.
Pretherius is offline
