Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Paint Marks
Thread: Paint Marks
Old 05-13-2012, 10:09 AM   #9
clnzx4
Keep It Classy.
clnzx4's Avatar
Fan#: 94624
What I Drive: 2007 ZX4 SAP, 2006 LJ Wrangler
Points 16,022, Level 81
Points: 16,022, Level: 81 Points: 16,022, Level: 81 Points: 16,022, Level: 81
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 2 clnzx4 Good Standing Member
Originally Posted by HCAutoDetail View Post
A long standing rule of thumb is to use the least aggressive method first. Gradually work your way up to something more aggressive. Now, with that said, I realize you don't want to go out and buy 3 or 4 different polishes to see what works. The thing to keep in mind while experimenting though, make sure to use a clean, soft, microfiber pad to do the polishing. If it's a light scuff from another car, it's likely that the paint transfer will come off pretty easy. Even with some bug and tar remover. But what you may find, and what I see all the time, is that deeper scuff marks will remain. In this case I'd suggest taking it to a pro and let them look at it. If you still want to tackle the deeper marks yourself, remember NOT to use something so aggressive that you rub more permenant damage into your paint.
Pics would help.
Good luck!
I'll post pics when I get back and can clean up the car. I've tried bug and tar removed. Didn't work.
Sent from my Desire HD using FF Mobile
Team Duratec #43 | Sedan Revolution #218
clnzx4 is offline
