Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - FSWERKS race header for my D23 PZEV? (Questions/tune)
Old 05-12-2012, 09:10 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,830, Level 95
Points: 24,830, Level: 95 Points: 24,830, Level: 95 Points: 24,830, Level: 95
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
Heres some options for you.
Originally Posted by Djzx3 View Post
I've read the basic bolt on's thread, but it didn't help much with my questions.
Basic Bolt ons: Exhaust Headers/Flex Pipes
I want to put the race header from FSWERKS onto my 2.3l, I know I need a new flex pipe and cat, along with a o2 sensor cheat for CT emissions.
IMO the Fwerk's header is the best.
My questions are, why do I need the o2 sensor cheat and why does the header only have one bung hole on it, When there are three o2 sensors for this PZEV model?
2 to monitor the before & after the convter.
Also, is this header going to fail visual inspections? If so is there a trick to it? Maybe a heat shield? You could take two stock 23 heat shield's & mod them to work= hide the header. Or do I need to wrap it anyways for heat? You could wrap it, but a official knowing what to look for, a header can't hide. The best flowing oem manifold/cat= a 23 ST manifold
If your inspector's know what to look for= yes it will fail then.
And what is involved in the tune? I have the OE Exedy fly/clt kit, with the Weapon R intake, and the exhaust done in 2.5 diameter trubenz piping from the cat under the car, back.
A tune will help out= turn off the rear o2 senser & egr, etc. A tune really helps out = makes your car more drivably, smoother.
Thanks, Hopefully Tom can stop by for the Tune questions, since I would probably buy it from him.
Djzx3
I run a Fwerk's header & tune w/ rear o2 senser & egr delete. The oem 23ST manifold/cat is the best flowing oem manifold. If you inspection= opening the hood, a header can't run & hide.
felixthecat is offline
