Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 5-Door tail lamp scratching body
Old 05-10-2012, 03:06 PM   #1
silenthill
Fan#: 85671
What I Drive: 2012 Focus SEL hatch
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
FF Reputation: 2 silenthill Good Standing Member
I've been having a strange recurring problem with my hatchback. On only the right side of the rear turn signal cluster, the fixture has been rubbing paint off and squeaking. Here's the original damage from the original cluster:
IMG_4102 by silenthill2011, on Flickr
The Ford dealer did replace this cluster, but it's chipping again. It's not visible in this picture because the cluster is pressed tightly against the body (which is causing the chipping):
IMG_4367 by silenthill2011, on Flickr
Has anyone else seen this problem? I don't have a problem with the lefthand cluster--there's plenty of clearance between the plastic housing and the fender. There's not on the right, and the dealer says there's no adjustment. They're looking into options, but I thought I'd see if anyone else has seen this.
silenthill is offline
