Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2.3 head differences?
Old 05-07-2012, 08:53 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,993, Level 94
Points: 23,993, Level: 94 Points: 23,993, Level: 94 Points: 23,993, Level: 94
Level Up 65% Completed
Forum Activity 100%
FF Reputation: 79 felixthecat Excellent Standing Member
Massive has cams for the '08+ motors
Originally Posted by d-coupe View Post
I made a post on FJ and didn't really get a real answer. What are the differences between the 2.3 head and the 08+ 2.0 head? Are the combustion chambers the same size? are the ports really that much better in the 2.3?what all needs to be done to run an earlier 2.3 head on a 08+ focus? I found a couple rebuilt 2.3 heads online and was thinking of running the crower springs-retainers and either the stg2 or stg2 turbo cams.
You should be able to bolt on a 23 head. Massive performance has cams for the '08+ motors. Are you going to add a turbo? Do the rebuild heads have 1 piece ss valves? If your going turbo, I'd probably run the 20 head. If not do a 23 head & go for the stage 1 cam. The ports are bigger but they both have the same size valves. I;m not sure of the cc's of each head. The compression is higher w/ the 20 thou. Hit Massive up.
felixthecat is offline
