Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Duratec Go-Fast Goodies Must GO! My Focus-Pile Spring Cleaning!!!
Old 05-06-2012, 10:59 PM   #27
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 9,559, Level 65
Points: 9,559, Level: 65 Points: 9,559, Level: 65 Points: 9,559, Level: 65
Level Up 70% Completed
Forum Activity 5%
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (11)
Originally Posted by Templar View Post
What would that SVT manifold do for a regular zetec? What is a IMRC? What is so special about the red housing vs the black housing tails?
Can someone tell me exactly where the rear bar mounts?
1.
The benefit would be maximized air flow for the zetec.
The dual stage intake manifold uses two sets of different length intake runners to maximize power AND driveability. "This device is designed to direct the intake air through four long runners below 6,000 rpm. Above 6,000 rpm, the manifold switches position to shorten the runners length, which improves peak power output. "
The intake manifold runner control is connected to the intake via cable and actuated via SVT ECU. (THAT may be the sticking point for most). The computer may be able to be told to use the IMRC if a factory Ford OBDII scan tool is used (need confirmation on that one!)... the ones that have done it just source the SVT computer and swap that in as part of the install.
2.
There is no difference other than color preference for the tail light housing. 99-02 used red, 03-07 used the black housings. I have red car; red housing would just keep a monochromatic color theme going for me.
3.
The rear stress bar mounts between the rear shock towers in the trunk/hatch area. You'd need to remove the trunk/hatch fabric, drill a hole (paint or zinc it to galvanize the exposed/untreated metal), run one bolt in and line up the other side and tighten them both down.
Sedan
Hatch
Mile30 is offline
