Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus Turbo Kit
Old 05-05-2012, 01:23 PM   #24
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
Points 6,438, Level 52
Points: 6,438, Level: 52 Points: 6,438, Level: 52 Points: 6,438, Level: 52
Level Up 44% Completed
FF Reputation: 2 700whpfocus Good Standing Member
Buy-Sell-Trade Rating: (11)
Originally Posted by bmylez View Post
When people put just bolt-ons on the MS3, the stock Crank Driven Fuel Pump starts failing from the increased pressure it has to run. New pump is $680. Then guys start running high fuel pressure on the new pump and sometimes blow out the Fuel Pump Relief Valve so they have to either get a stronger RV and rig it up, or turn their fuel pressure down. Also, one guy making LESS than 500whp is at I think 98% injector duty cycle. Guess what? Nobody makes higher flowing injectors.
Another problem is that direction injection only gives you a small window to inject fuel. With port injection, you have way more wiggle room. There's a reason that a guy in the Ukraine put custom port injectors into his intake manifold so that he could get reliable fuel at the 500whp mark.
Direct injection is more efficient, but not really geared towards making lots of power. Yes, the Coyote motor is a beast, but take an old port injected 5.0, build it to hell, and slap a couple of GT40s on there. You will make the power more easily without the hassle of DI.
I believe in one of the new performance magazines, there is a stock looking MS3 making over 600whp.
700whpfocus is offline
