Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2003 cruise control shuts off
Old 05-04-2012, 04:28 PM   #36
Iraconji
Fan#: 97329
What I Drive: 2004 Arizona Beige Focus ZTW
FF Reputation: 1 Iraconji Good Standing Member
I suspect its not the stereo, just kind of weird it stopped working right after the install.
Yes, you're correct, the little dash indicator light has not worked since I
ve owned the car but the CC has worked regardless.
Since the indicator light does not work I have no way to diagnose it. I've checked all the fuses and tested the pedal switches and they seem to be working fine. Even tried a road test while having the switches jumped with wire, still no luck.
Not sure where to go from here other then the dealer, or a different dealer just to double check.
Dave
Originally Posted by Tiger-Heli View Post
Okay, that's weird.
Lots of things don't add up here.
The JVC stereo should have zero interface with the CC system - unless it was a navigation model that tied in with the brake light switch, and even then.
Also - you are saying the cruise worked fine before the stereo was installed, but the dash light never worked - not sure that was correct.
Not likely the servo can be repaired, but if I looked it up properly, SilverStateFord shows it as MSRP $171.82 and their price $121.44 plus shipping. You could also PM b16sir1991 - He works at Hillbish Ford in NC and has gotten good deals for me previously.
Verify that it is indeed the servo before you dig into this, though.
Iraconji is offline
