Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - NO indicator for winshield wiper fluid
Old 05-04-2012, 10:29 AM   #50
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,831, Level 25
Points: 1,831, Level: 25 Points: 1,831, Level: 25 Points: 1,831, Level: 25
Level Up 31% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by raptor1956 View Post
It would be nice to have a coolant level alarm but I'd guess the engine coolant system is a bunch tougher to sensorize than washer fluid. First, it's hot. Then you have the water pump causing the fluid to be quite turbulent. Finally, it's pressurized so whatever sensor would need to be fully enclosed.
Should still be doable, but certainly not as easy as washer fluid.
A similar thing with motor and transmission oil levels.
Brian
Putting a sensor in the coolant overflow bottle would reduce those issues. As you mention, oil is also hot and pressurized, and most vehicles have oil level sensors.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
