Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - NO indicator for winshield wiper fluid
Old 05-04-2012, 10:10 AM   #49
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 5,996, Level 50
Points: 5,996, Level: 50 Points: 5,996, Level: 50 Points: 5,996, Level: 50
Level Up 23% Completed
FF Reputation: 1 raptor1956 Good Standing Member
Originally Posted by Kabigon View Post
There is no mechanism to detect a low coolant level directly (i.e. it could only be detected by a high coolant temperature).
It would be nice to have a coolant level alarm but I'd guess the engine coolant system is a bunch tougher to sensorize than washer fluid. First, it's hot. Then you have the water pump causing the fluid to be quite turbulent. Finally, it's pressurized so whatever sensor would need to be fully enclosed.
Should still be doable, but certainly not as easy as washer fluid.
A similar thing with motor and transmission oil levels.
Brian
raptor1956 is offline
