Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - NO indicator for winshield wiper fluid
Old 05-03-2012, 08:33 PM   #41
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
TSB
12-4-13 LOW WASHER SOLVENT WARNING MESSAGE MAY NOT DISPLAY ON VEHICLES BUILT ON OR BEFORE 1/14/2012
Publication Date: April 30, 2012
FORD: 2012 Focus
ISSUE:
Some 2012 Focus vehicles built on or before 1/14/2012 may not display the low washer solvent message as detailed in the Owner's Guide.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Using the Ford Integrated Diagnostic System (IDS) start a new IDS session.
ID the vehicle; select the tool box at the vehicle screen.
Select module programing.
Select programmable parameter.
Select car configuration parameters.
Select vehicle configuration.
Retrieve professional technician society (PTS) delivered as-built data.
Follow the on-screen prompts.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
120413A 2012 Focus: Follow Service Procedure To Repair Concern (Do Not Use With Any Other Labor Operations) 0.3 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
14A068 04
Rat Fink is offline
