Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rattling from door area stereo when playing music?
Old 05-03-2012, 06:51 PM   #51
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2015 White ST3
Points 534, Level 10
Points: 534, Level: 10 Points: 534, Level: 10 Points: 534, Level: 10
Level Up 68% Completed
FF Reputation: 5 noahsfocus Good Standing Member
Originally Posted by BigFuzzyArchon View Post
I fixed my noise from my passenger door.
I took the rubber cover for the wiimote and cut a few square pieces. One piece I put down into the cubby inbetween the front plastic piece and the base of the cubby. Then I put two more pieces of rubber underneath the door plastic in between the metal of the door.
The rattling is 100% gone. So much happier now.
This sounds like a simple and effective solution for the speaker/door panel rattle issue. I just noticed mine is starting to do this.
Can you explain a little better or take a few pics of the places you inserted the rubber? What is a wiimote exactly? I think I know where to put the pieces underneath the door panel but not sure where it was the first piece you mentioned goes. I will look at the cubby closer and try to figure it out anyway.
Thanks
noahsfocus is offline
