Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - cdbertrand's slow build thread.
Old 05-03-2012, 09:25 AM   #45
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 12,146, Level 72
Points: 12,146, Level: 72 Points: 12,146, Level: 72 Points: 12,146, Level: 72
Level Up 24% Completed
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
Originally Posted by cdbertrand View Post
i thought you had a cai? and i know i'm trying to get it off but the bolts on the bottom are rounded it looks like. and the damn molded plastic piecei can't get a wrench in.
This came off AEM's website, Looks like it pulls straight up, I think those are clips not bolts
Removal of stock system
a. Loosen the hose clamps attaching the primary stock intake pipe to the throttle body and the primary stock
intake pipe to the mass air flow sensor.
i. Remove the primary stock intake pipe.
b. Disconnect the wiring harness from the mass air flow sensor.
c. Remove the mass air flow sensor from the stock intake piping using the supplied torx tool and set aside as it
will be used in the installation of the AEMŽ intake. Be careful not to damage the mass air flow sensor.
d. Remove the breather hose from the valve cover to the air cleaner housing.
e. Remove the air cleaner housing from the vehicle. This is done by pulling straight up on the housing. There
are no bolts holding the housing in.
f. Unfasten the battery by removing the battery strap.
g. Carefully lift the battery out of the car and place in a safe place.
h. Remove the battery tray.
i. NOTE: Be sure to disconnect any harnesses that may be attached to the tray.
i. Remove the two plastic hold downs from the secondary intake tube.
j. Remove the secondary intake tube from the engine mount by lifting straight up.
k. Remove the secondary intake tube through the front of the vehicle.
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
