Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - !! Steeda CAI Results Only !!
Old 05-01-2012, 06:06 PM   #9
Duffman355
Rebecca
Duffman355's Avatar
Fan#: 31282
What I Drive: 2016 White Focus ST
Points 24,210, Level 94
Points: 24,210, Level: 94 Points: 24,210, Level: 94 Points: 24,210, Level: 94
Level Up 86% Completed
Level up: 86% Level up: 86% Level up: 86%
Forum Activity 100%
FF Reputation: 43 Duffman355 Great Standing Member
Ok as promised *cracks knuckles*:
Still comes in the same white Steeda box. Nice packaging as usual. Instructions were numerous but pretty simple and easy to follow. Parts were well made and all the holes lined up with the screws etc. The only thing I had to do was bore out one of the holes with my drill becasue I couldn't thread it by hand with my screw driver. It is a bit of a tight squeeze to get the completed unit inside but it not a huge deal. The hood does indeed seal with the top of the airbox as Steeda Brandon advertised (you could see a slight indentation in the soft foam of the hood from the airbox after it was closed and I drove it). Also the air filter is rather large. Install took me an hour, hour and a half. The only thing is; make sure you have one of those nice Craftsman 23 piece screwdriver with the magnetic insertable tips. You need various sized allen wrenches, a torx bit for the stock maf screws, a flat head and something else. Also don't mind the dirty steeda fuse box cover. I am still waiting on it to seal before I can give it a good wipedown.
Pic? Pic:
Also since I like Steeda, I am rocking their window decal (it came with the instructions). That has to be good for atleast 5 more horsepower.
So I suppose you want to know how it drives. As previously stated I already have the FS Werks race exhaust, so I was not expecting it to be any louder, just deeper in tone under throttle.
Startup: Sounded the same at idle. Revving it with the hood open gave some slight whooshing, which was not really as noticeable with the hood down due to loud exhasut.
Normal acceleration: Again sounds the same to me since I have my exhasut. No real difference in tone.
WOT: Sounds wicked! You really start to hear it at 3,000 rpms, and with the windows shut it almost sounded like secondary intake runners kicking in at 4,000. Windows down it is deep and throaty throughout the band. You can definitely hear it.
Performance? I definitely think it feels quicker throughout the rev band (remember the car isn't any louder really so I am not just thinking this becasue of more noise). Even at highway speeds in high gear it pulls harder.
So the much debated 20 pounds of torque gained down low?
I did launch it and only got minor wheel spin, but I don't think it really bogged or had that lag in acceleration as much. Note I am running 93 octane, so say what you will about that as well.
All in all, I think this car is quicker than the my old ST with the same mods. The gearing is a bit different but I still think this one is quicker. It does sound better too since the exhasut has only the one internal cat in the head that I still have on there, hence making it deeper and less raspy. I actually like the heat shield much better on this one as opposed to the old one. It is a better simpler design and I think this one is blocked off from the heat better too. I also like the fact that they retain the stock snorkel so it is pulling in colder air without the risk of hydrolock.
So the question to yourself is what to buy first intake or exhasut? Sound vs. power. While the exhaust does add power, the intake adds more and together they bring out the best in eachother. Personally I couldn't stand the lack of exhasut note (and Injen might had been the only intake out at the time) so I went with exhasut. The dual tip is sexy. Since I didn't post up a pic of my plastidipped stripes during the day here you go.
ST Crew #11
Official Mayo Hater #1
Randomie's Lover #8
Focus Takeover #013 / Tarbo Fan # 001
Last edited by Duffman355; 05-11-2012 at 01:31 AM. Reason: Updated pic! Fail!!!!!!
Duffman355 is offline
