Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - P/S delete
Thread: P/S delete
Old 04-30-2012, 11:08 PM   #32
PowerFocer
PowerFocer's Avatar
Fan#: 61706
What I Drive: 2010 Sedan SE
Points 4,602, Level 43
Points: 4,602, Level: 43 Points: 4,602, Level: 43 Points: 4,602, Level: 43
Level Up 26% Completed
FF Reputation: 2 PowerFocer Good Standing Member
Originally Posted by Mike_Mac View Post
without fluid the rack will function the same way as a manual rack but will require much more force. you will need to keep it lubricated by either looping the lines or setting each side up on a resivoir. if its not lubricated the rack will eventually bind up.
personally i would be more worried about putting all that stress on the torsion rod/bar. this bar twists and is what controls the valves for fluid flow. when you are putting all that extra effort into low speed turning it could go from elastic to plastic deformation and possibly break after time.
All power assisted racks will function normally as a manual rack as a safety feature if the power assist where to fail, but they are in no way designed to take prolonged exposure to driving with no assist.
^^ Fluid is not required for the rack to function, you are looking at the system in the wrong way. its a mechanical system that has a hydraulic assist.
This. Much more clear than I could manage to put it apparently
Rule of thumb:
NEVER trust anyone with your car or your girl.
Either way, you could get a rod thrown in both.........
Fast cars make smart people do dumb things
PowerFocer is offline
