Old 04-26-2012, 11:53 PM   #191
thelongone13
thelongone13's Avatar
Fan#: 95644
What I Drive: 2012 Oxford White Focus SE Hatch
Points 872, Level 15
Points: 872, Level: 15 Points: 872, Level: 15 Points: 872, Level: 15
Level Up 72% Completed
Forum Activity 4%
FF Reputation: 1 thelongone13 Good Standing Member
Clunking relating to the sway bar usually is due to the bar being cracked. Usually. Well, on cars I have actual experience with. I would say clunking is usually a ball joint, hub/bearing assembly, tie rod, or blown strut/mount. In motion over bumps, it's likely a hub/bearing, strut, mount, or ball joint. In turning, it's usually a tie rod, or if it is sway bar related, that's when you'll hear it.
Edit: endlinks will clunk whenever the they want, because they hate you, as far as I recall.
2012 Oxford White Focus SE Sport w/DCT (ugh)
A Ford Focus driver with ADD
thelongone13 is offline
