Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to cut a fuel pump access panel/door.
Old 04-26-2012, 04:56 PM   #7
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Nice job.
I like the way you used the flooring from another Focus to make a cover.
I wish I had cut my access panel, used a nibbler - too worried about the wiring underneath, a littler larger because that BLUE screw lid can be a b!tch to get back on and the cut sheet metal will slice up your hands. Probably won't have to open this up again on this car.
The other nice thing about cutting a opening for the fuel pump assembly is - it also provides access to the fuel filter hose connection in the pump assembles lid (black hose with the red male connector). In the case where that hose gets damaged when changing a fuel filter and needs replacement.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
