Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help. 2000 Zetec spitting out coolant from plug holes on valve cover!
Old 04-25-2012, 12:45 AM   #25
CitizenPete
CitizenPete's Avatar
Fan#: 97222
What I Drive: 2000,ZX3,Blue,3DR,Auto,2.0ZETEC16
FF Reputation: 1 CitizenPete Good Standing Member
Smile Ran the Steel Seal trough the coolant system.
I drained the coolant, removed the thermostat and replaced the housing with just the gasket from the thermostat. Then I ran with the Steal Seal and distilled water as recommended for 1/2 hour, then letting the engine cool and repeating. Then I drained the Steal Seal and will replace the thermostat and put in new green coolant at 50/50 mix.
I did purchase a new housing and thermostat, but so far I don't think I will need it, unless I break something on the next R&R. It is fun get that thing out of there.
While the thermostat housing is out I need to replace the PCV hose, which has a gaping hole in it behind the motor. Then I'll replace the thermo housing and tube and refill.
I did the fuel filter today as well.
Time will tell on the sealer. If I see anything on inspection or any side effects from the sealer I will post again.
Thanks for the help.
Learning more and more about the Focus every day.
2000 Ford Focus Zetec 2.0L, blue, 3 door, automatic, lots of miles. "If something cannot go on forever, it will stop," Herbert Stein.
CitizenPete is offline
