Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2.0 to 2.3 swap
Thread: 2.0 to 2.3 swap
Old 04-22-2012, 12:04 AM   #13
fastfocus2005
Fan#: 72541
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 1 fastfocus2005 Good Standing Member
I did this swap in my car and you do have to do the things as stated above....but I did find you only need to change the engine side of the harness for the 2.3 since it has IMTV AND IMRC(tumble flaps). The 2.0 only has IMRC so the 2.0 harness will technically work, but it only has the one connector for the IMRC. The 2.3 harness plugs into the vehicle harness without changes as well as the 2.3 PCM plugs into the original harness in the car so changing the harness that passes through the firewall is unnecessary. The only other thing you will have to do is have your keys reprogramed to the 2.3 PCM or your car will not start.
fastfocus2005 is offline
