Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - M-3000-ZX3 kit questions
Old 04-16-2012, 09:39 AM   #15
JakeTheSnake
Fan#: 97620
What I Drive: 2004 Twilight Blue ZTS, 2.3L PZEV
Points 497, Level 9
Points: 497, Level: 9 Points: 497, Level: 9 Points: 497, Level: 9
Level Up 94% Completed
FF Reputation: 1 JakeTheSnake Good Standing Member
Originally Posted by sailor View Post
Well, on mine the warning light came on intermittently with NO cause - Fluid fine, checked fluid level switch, brake lever switch YaDa, YaDa.... New Cluster & no foolish lights that didn't make sense....
On Yours, remember that the clutch is from the same reservoir when you're checking for leaks.....
(FWIW)
My ZTS has an automatic transmission.
My kit arrived today! I'm excited. My preferred local auto parts store has everything else I'll need - if not in-store then just 1 day away.
I must get some PB Blaster too for those rear bolts! At one time I tried to get the rear shock absorber bottom bolt loose - holy crap there was not way in hell. Maybe PB Blaster will help...
JakeTheSnake is offline
