Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: Adding an OEM Tachometer Cluster on a 2005-up
Old 04-14-2012, 05:35 PM   #112
Lscman
Fan#: 95211
What I Drive: 2007 ZX3 5spd, 2012 SE Sedan Auto
Points 1,639, Level 23
Points: 1,639, Level: 23 Points: 1,639, Level: 23 Points: 1,639, Level: 23
Level Up 39% Completed
Forum Activity 9%
FF Reputation: 9 Lscman Good Standing Member
The dummy upshift light will probably be disabled if you install a cluster from an automtic car. However you could also remove the upshift bulb from a manual cluster to achieve the same result, I suspect. The ABS vs non-ABS is a serious difference and I'd try to get the right type.
In swapping clusters, I'd try to find one for a car with similar options. There are enough selling on ebay with engine specs shown to do that. if you don't mind spending a few extra bux for a close match or living with a cluster that shows more mileage. A used cluster can't be reprogrammed and it looks like many folks posting in this thread are missing that point.
Lscman is offline
