Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus Flat Towing questions
Old 04-13-2012, 12:09 AM   #8
OreFocus
Fan#: 97605
What I Drive: 2012, Red, Focus Titanium
FF Reputation: 1 OreFocus Good Standing Member
Talked with a tech at my dealer about this. He suggests removing the cable connector from the negative battery post (not at the ground lug) to make sure ALL cables leading from the negative post are disconnected prior to towing.
If you remove the connector from the post, you can see there are TWO cables leading from the negative battery post, not just the one connected to the frame off to the side
Last edited by zetecDon; 07-06-2012 at 09:27 PM. Reason: Fixed it so you would have an image there instead of a red x.
OreFocus is offline
