Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - M-3000-ZX3 kit questions
Old 04-12-2012, 06:14 PM   #3
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,531, Level 100
Points: 30,531, Level: 100 Points: 30,531, Level: 100 Points: 30,531, Level: 100
Forum Activity 100%
FF Reputation: 128 sailor Excellent Standing Member sailor Excellent Standing Member
I used the M-3000-ZX3A kit from Tousley, that one comes with pre-assembled front struts so I didn't need the mounts & bearings that you will need. It also did NOT come with a rear SVT bar, so I'm still using the stock one.
You should use new sway bar bushings to fit the new bar, being a ZTS you SHOULD have a rear bar already...
Interesting that you have a PZEV 2.3 in Michigan, since that isn't a "California" state or next door to one, unless you count across Canada to N.Y. as being next door...
My Lower arm bolts were frozen at lower mileage, left them alone for now as the bushings weren't sacked yet when I installed the kit.
Agree with Geezer that you could use them, plan on new bolts as you'll be cutting them most likely....
I broke a sway bar link not too long after the kit went in, since you have to get one end loose anyways for the install it WOULD be a good time for replacement....
Luck!
sailor is offline
