Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Timing Belt Change...The Stuff You Never Seem to Hear About!
Old 04-12-2012, 05:08 PM   #21
03#1965's Avatar
Fan#: 66541
What I Drive: 2003 Pitch Black SVT
Points 505, Level 10
Points: 505, Level: 10 Points: 505, Level: 10 Points: 505, Level: 10
Level Up 10% Completed
FF Reputation: 3 03#1965 Good Standing Member
Originally Posted by 1turbofocus View Post
Why take the Cam gears loose at all ?
Ya know, Tom, the more I think about Ford's process on this, the less I understand it. If the car is running good when you remove the old belt, why would they even suggest you loosen the cam gears???? Once the crank is at TDC, the belt is removed and the timing bar is slipped into the cams, everything is as good as it's going to get, right? So at that point you just index the cam gears to each other with a Sharpie and a straight edge, remove the timing bar and tension the new belt on. As long as the cam gear marks stay dead on, it's all good, right? What am I missing?
Ed, Nashville
03 SVT Focus #1965
86 XR4Ti 5SPD
03#1965 is offline
