Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Headlight Issue
Thread: Headlight Issue
Old 04-10-2012, 08:27 PM   #6
Tymes
Fan#: 94124
What I Drive: 02 SE SOHC SPI
FF Reputation: 8 Tymes Good Standing Member
The main reason I suggest that is if right now when you have low beam on, and your driver side is actually in high beam mode, and you move it to the passenger side and it is still in high beam mode, then you know it is a factory defect. If it is in low beam mode like it should be when it's moved over then you know its the wiring itself.
Trust me, nothing sucks worse then looking for a wiring issue when you have no chance of ever finding it. My car is a bit different, but if its any indication, the headlights are quite easy to remove, mine take less then 5 mins to pull out.
Tymes is offline
