Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Solution to cooling fan resister failure???
Old 04-10-2012, 08:06 PM   #8
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
I think we're missing something here.
The Fan Resistor is a current limiting resistor/ dropping resistor. That may be why the 'low speed' circuit only needs a 30A fuse.
The high speed circuit has no series resistor, the Fan Resistor, and needs a 50A fuse.
If you short out/bypass the Fan Resistor you may exceed the 30A fuse value.
If you replace the 30A fuse with a 50A fuse you may exceed the wires current rating associated with it if it is not the correct gauge wire.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
