Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - I must be getting old... :-) DIY 2012 intake modification
Old 04-10-2012, 05:22 PM   #36
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,497, Level 42
Points: 4,497, Level: 42 Points: 4,497, Level: 42 Points: 4,497, Level: 42
Level Up 74% Completed
FF Reputation: 9 darkangelism Good Standing Member
Originally Posted by zx3matt View Post
Yes I do. I will check when I get a chance.
cool thanks, no rush, really i just want something to compare to once i get my setup done. I think the maf numbers should show your mod helps over new missions by itself. From my research ford uses the same maf sensors on all their cars so this one should be able to handle the same air flow rate as higher HP cars, so it should not reach its limit and start causing incorrect readings that cause the air/fuel ratio to be off.
darkangelism is offline
