Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Solution to cooling fan resister failure???
Old 04-10-2012, 01:13 PM   #3
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
The engine would still maintain operating temperature in the lower range but.....
The fuse may be your number one problem (30A), followed by melting your wire harness 'somewhere' if you try replacing a 30A fuse with a 50A fuse.
Wouldn't recommend it.
Would recommend fixing the original problem correctly.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
