Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Timing Belt Change...The Stuff You Never Seem to Hear About!
Old 04-09-2012, 08:45 PM   #12
blackonblacksvt03
blackonblacksvt03's Avatar
Fan#: 80038
What I Drive: 2003 pitch black SVT 3D
Points 2,535, Level 30
Points: 2,535, Level: 30 Points: 2,535, Level: 30 Points: 2,535, Level: 30
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 2 blackonblacksvt03 Good Standing Member
Buy-Sell-Trade Rating: (5)
no what i need to know is what i did wrong, timing tool in the cams and crank sitting on the pin. where do i need to turn the intake cam because even with the cam gear tight the part where the belt goes will turn. So do i need to turn the gear to where it stops clockwise or counterclockwise or somewhere in the middle. i have changed alot of reg focus belts but this is my first SVT
The best modifications cannot be seen from the outside.
I work on Fords all day so more than likely i know more about your car than you.
blackonblacksvt03 is offline
