Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: Adding an OEM Tachometer Cluster on a 2005-up
Old 04-05-2012, 07:30 AM   #107
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 2,736, Level 31
Points: 2,736, Level: 31 Points: 2,736, Level: 31 Points: 2,736, Level: 31
Level Up 91% Completed
FF Reputation: 4 Tiger-Heli Good Standing Member
Short answer is you are either going to have lights on or be missing lights.
If your car did not have ABS and you put an ABS cluster in, the ABS warning light will always be on (unless you remove the bulb or spray paint over the light or similar).
If your car has ABS and you put in a non-ABS cluster, you will never see the warning light if the ABS system malfunctions.
Tiger-Heli is offline
