Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Daytime running lights (DRL)
Old 04-04-2012, 05:18 PM   #82
03rubicon's Avatar
Fan#: 95694
What I Drive: 12 SE Hatch, 03 Rubicon
FF Reputation: 2 03rubicon Good Standing Member
The only thing that may make them hesitant about doing that is in the shop manual it says you should only change a few of the parameters in there. DRL is not one of those the shop manual says you should change. I'm guessing they either read this and decided against changing it for you or they didn't put muh effort into it. But there was no warnings or messages on IDS when inchanged mine. Another thing I think may be throwing them off is the fact that the procedure to change the parameters in this is a lot different then anything before. It took me a few minutes to figure it out, but once I figured it out it took all of 10 minutes to change it. I have changed mine without any issues as of now, I am going to do a friend of mine's car when I get a few minutes. His is an earlier build so i want to see if it works on his before I go into depth about how to change it.
03rubicon is offline
