Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - clear cover for MFT screen protection?
Old 04-04-2012, 07:20 AM   #11
Fan#: 95657
What I Drive: 2012 Black Focus SEL
FF Reputation: 1 mattphoto Good Standing Member
i had no problem with it. it has the standard front and backing to prevent you from getting prints or scratches during install, also you can peel it and replace as long as you don't bend it too much or touch the sticky surface.
I have had a lot of practice applying these things. I do them for all my friends and family, so I am pretty good at it. I recommend watching youtube for tips on applying these. Also i recommend using scotch tape on the front edges of the protector to make removable handles for better application and positioning. The bevel of the MFT doesn't allow your fingers to get close to the edges of the screen, so the tape handles will not only help with application, but with removing the front film once it is stuck on.
As always, apply one edge first, then slowly apply in a parallel motion across the screen while peeling the backing. squeegie bubbles out with a credit card, then remove the front film.
mattphoto is offline
