Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - High Nox emissions after rebuild
Old 04-02-2012, 05:34 PM   #3
SPI Tuner
Fan#: 47140
What I Drive: 2001, Red, LX
Points 90, Level 1
Points: 90, Level: 1 Points: 90, Level: 1 Points: 90, Level: 1
Level Up 80% Completed
FF Reputation: 1 SPI Tuner Good Standing Member
NOX is because you car is getting to hot. The EGR system puts burned gases back in to the cylinder to reduce NOX emissions. So yes you are right. Since I'm guessing you live in Cali the emissions standards take that into consideration. So yeah check you EGR flow with a vacuum pump on the EGR test port. If you surpass 4.2 in/hg of vacuum and the engine doesn't start to idle rough then that is your problem.
SPI Tuner is offline
