Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - bad rear brakes on 2012
Old 03-30-2012, 11:57 PM   #11
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 29,449, Level 99
Points: 29,449, Level: 99 Points: 29,449, Level: 99 Points: 29,449, Level: 99
Level Up 67% Completed
Level up: 67% Level up: 67% Level up: 67%
Forum Activity 100%
Well, you SHOULD use it occasionally, or someday when you need it it won't work!
And notice the OTHER common culprit, a mechanical issue causing it to drag....
BOTH are more common than defective pads or rotors.... Not that it COULDN'T happen, I just haven't seen a case yet....
Luck!
( I always like to hear a reason for a failure, even if it's fixed under warranty...)
sailor is online now
