Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A simple fix for the microphone wind noise issue
Old 03-30-2012, 02:46 PM   #118
cacophonous
cacophonous's Avatar
Fan#: 89165
What I Drive: 2012 Focus Ti & 2005 Saab 92X Aero
Points 1,776, Level 24
Points: 1,776, Level: 24 Points: 1,776, Level: 24 Points: 1,776, Level: 24
Level Up 76% Completed
FF Reputation: 2 cacophonous Good Standing Member
Originally Posted by Dysan911 View Post
cacophonous,
Cool how is that held up there? If it's tape is it sticking directly over the mic grill or is that unobstructed and allowing sound to pass through the material directly into the mic?
I was looking around for something like that and can't find anything. Bummer!.
@Robbie - Was there anything done to yours other than the MFT Upgrade and do you have a sunroof as well?
No moonroof. I used thin double sided tape to hold it on. It is unobstructed.
Remember it is a crude proto to test with. :)
I took a small extra foam cover from a ear bud head phone set. I cut a thin piece of plastic out of a flexible cd jewel case with scissors to insert inside to make the foam slightly oval shaped to cover the entire mic.
I cut the double sided tape with scissors:
If this works well I will try to make it look better.
2012 Focus Titanium HB, Yellow Blaze, 400A, Winter, & 17" Black Machined Rims
cacophonous is offline
