Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT springs vs FRPP kit; comfort, ride & handling
Old 03-30-2012, 02:59 AM   #93
karmakc
karmakc's Avatar
Fan#: 78622
What I Drive: 2013 TS FoST; SOLD 2004 Ag ZX3 D23E
Points 2,976, Level 33
Points: 2,976, Level: 33 Points: 2,976, Level: 33 Points: 2,976, Level: 33
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 2 karmakc Good Standing Member
Originally Posted by Foci-runner View Post
Funny thing is....
When I bought my car it had a bent strut on drivers side, two bald tires on front, key marks everywhere, a cracked windshield, craked headlight and wrinkled front pass. fender- it needed some work. but mechanically it was sound and the interior is immaculate. It only had 74,000 miles and I got it for just under $2,000. I did my research and found out it was worth almost $5,000 in good condition. So I bought it with the intent of just fixing everything wrong with it and turn around to sell it.
But now I am hooked on it and researching all the info on Foci on this forum just made matters worse. There is a lot you can do to these cars I didn't know about. back to the point- I replaced the front struts and rear shocks and took it in to have an alignment done already after putting two new front tires on also. It was spot on (except the pass. side had excessive toe out because I had to replace the outer tie rod and the replacement tie rod body was longer than the OEM so even when I screwed it back on with the same number of rotations it stuck out too far.
Had I knew that I was going to catch the "Focus Bug" I would have waited until after I had my new wheels/tires/suspension on before getting the alignment.
As of now I have brand new OEM suspension all the way around and would really prefer not to have to replace them until after my zetec install. I don't even have a rear sway bar (as of yet) But plan on getting one when I see a good deal pop up on this forum.
I know the lowering springs might kill the longevity of the stock springs/struts but they have a lifetime warranty and I don't plan on waiting too much longer to do the Zetec Swap which is when I will put in the new suspension. Right now I am just trying to bring it down a little lower to earth and will worry about the performance handling side of it a little down the road. If the ride Is really too rough then I may just not have it aligned and put the stock springs back on and wait to do the springs when i get the stuts
Wow! That's quite a story!
Are you swapping in another Zetec? Why not just get a Duratec 2.3/2.0?
The major issue you will see is that the stock/oem struts and shocks simply won't be up to par when it comes to the rebound rates with the FRPP springs. At the end of the day, I don't think anyone can/will stop you from doing what you want to do - however I'm not really sure if it is even safe to use the stockers.
As for your rear sway bar, I have a stock rear sway bar for sale. Hit me up if you'd like more information.
Have you finished fixing/installing new headlights? I purchased some mach headlights and have very clean stock headlights also for sale. Just saying :)
Btw TireRack has a 20% sale on Koni struts and shocks, both adjustable and non-adjustable. Check it out.
Hatch Nation #135
Blazin' the Twisties #90
karmakc is offline
