Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - rockford build
Thread: rockford build
Old 03-30-2012, 01:36 AM   #57
Gazookz
Gazookz's Avatar
Fan#: 82103
What I Drive: 2011 Metallic Gray Focus SE
Points 658, Level 13
Points: 658, Level: 13 Points: 658, Level: 13 Points: 658, Level: 13
Level Up 16% Completed
FF Reputation: 5 Gazookz Good Standing Member
Originally Posted by alaskanzx5 View Post
if thats how you would rather do it. kenitic makes good batteries. basicaly as long as you have the ho alt your system will be powered while driving and the upgraded battery is just to keep it powerd for those short time periods while at stops signs/lights.
That isn't exactly how it works....you need instantaneous current draw to power your amps which an alternator cannot provide. You still need batteries nearby to help keep your amps supplied with current or they can possibly be damaged from overheating from lack of power or something else can go wrong. If you want to conduct the experiment yourself just unhook your battery/s even your under the hood battery when your car is on. Rev the engine to around 2k RPM and play your music and monitor the voltage and see how much warmer your amp gets. If that were the case then everybody who competes with 10k watts or less would run a few alternators and keep the RPM up. They do not do that - they have multiple batteries in a huge bank to power their setups even while the car is on and even if they do have multiple alternator's that can provide the current they need.
Gazookz is offline
