Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yanner's 2012 stereo install
Old 03-29-2012, 08:21 PM   #8
Fan#: 85222
What I Drive: 2012 S.Grey SE Spt,4dr,Wint,MR,6sp
FF Reputation: 1 voipguy Good Standing Member
You Said
"I tapped into the factory speaker wires directly underneath the shifter. I ran all 8 (4 for the line level inputs and 4 return amplified outputs) basically in a straight line from under the shifter to the hatch area. Getting through the tunnel was probably the toughest part and I don't know if I'd take that approach again."
So im not confused the wires you tapped into go to the LOC correct? for Front Right and Left and Rear Right and Left? Did you use the existing speaker wire??
I wonder what the steps are to remove the plastic side panels to run the speaker wire on the right side and the power wire on the left side?
voipguy is offline
