Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lets see your 1/4 mile times
Old 03-29-2012, 07:05 PM   #133
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
What I Drive: 1998 Ford Escort ZX2
FF Reputation: 1 AllOutZX2 Good Standing Member
Originally Posted by SMITHBOY76908 View Post
Pretty much this!
I'm running 24.5 x 8 slicks on the front with 25.5 x 4 skinnies on the back with Koni adjustable rear shocks set as stiff as they'll go. I'm building ~7psi on a 4000rpm 2-step which is nice with the manual because it doesn't load the suspension. The FSWerks lower stress bar, control arm poly bushings, and LSD did wonders on reducing wheel hop.
I'm pretty much in the same boat as elsolo. Being a fox body / radial tire car guy for so long, learning to launch this car was a whole new experience. Trying to apply some of the same principles from a RWD to a FWD didn't turn out so well. Just learning how to launch FWD took me from a 14.18 on my first pass to a 13.42 on street tires. Slicks got me in the 12s.
You could get extreme and install wheelie bars :) It's more challenging to get a FWD to hook then rwd, the weight transfer isn't going where you need it to. I mean in a RWD first thing I would do is pop that front sway bar off, in a FWD if anything I would add a larger one so it keeps both front tires planted evenly.
Shawn
Full Bolt-On's, SCT VCT Tuned ECU, 3500rpm Edge Racing Stall, 205/60R13 M&H D.O.T Street Slicks
AllOutZX2 is offline
